This is related to uvm_1.1 example intergrated/ubus/
In class test_2m_4s (in file test_lib.sv), the ubus_example_tb0.ubus0.num_masters is set to 2 with following code:
uvm_config_db#(int)::set(this, “ubus_example_tb0.ubus0”, “num_masters”, 2);
In class ubus_example_tb (in file ubus_example_tb.sv), the ubus0.num_master is set to 1 with following code:
uvm_config_db#(int)::set(this, “ubus0”, “num_masters”,1);
Because the testbench is built top-down, I expect that the num_master value 1 set by class ubus_example_tb should override 2 which is set by test_2m_4s, which is sitting in upper level.
However, the simulation shows that the final value of num_masters is 2.
Can anyone explain why?
Thanks in advance and best regards,
Xun
