Why starting_phase in pre_body()/post_body() is null object?
In order to understand UVM certain points, I create a simple UVM codes as follow:
import uvm_pkg::*;
`include "uvm_macros.svh"
typedef class packet;
typedef uvm_sequencer#(packet) pkt_sequencer;
class packet extends uvm_sequence_item;
   rand bit[7:0] pkt_id;
   function new(string name="packet");
     super.new(name);
   `uvm_object_utils_begin(packet)
      `uvm_field_int(pkt_id, UVM_ALL_ON)
   `uvm_object_utils_end
endclass // packet
class pkt_sequence extends uvm_sequence#(packet);
   `uvm_object_utils(pkt_sequence)
   function new(string name="pkt_sequence");
      super.new(name);
   endfunction // new
   virtual task pre_body();
      if(starting_phase != null) begin
	 `uvm_info(get_type_name(), $sformatf("%s pre_body() raise objection[if], %s", get_sequence_path(), starting_phase.get_name()), UVM_LOW)
	 starting_phase.raise_objection(this);
      else begin
	 `uvm_info(get_type_name(), $sformatf("%s pre_body() raise objection[else]", get_sequence_path()), UVM_LOW)
   endtask // pre_body
   virtual task post_body();
	 `uvm_info(get_type_name(), $sformatf("%s post_body() raise objection[if], %s", get_sequence_path(), starting_phase.get_name()), UVM_LOW)
	 starting_phase.drop_objection(this);
      else begin
	 `uvm_info(get_type_name(), $sformatf("%s post_body() raise objection[else]", get_sequence_path()), UVM_LOW)
   endtask // post_body
   virtual task body();
      `uvm_info(get_type_name(), $sformatf("%s body() Starting sequence ...", get_sequence_path), UVM_LOW)
      `uvm_do_with(req, {pkt_id == 'hff;})
   endtask // body
endclass // pkt_sequence
class test1 extends uvm_test;
   pkt_sequence  m_seq;
   pkt_sequencer m_seqr;
     super.build_phase(phase);
      m_seqr = pkt_sequencer::type_id::create("m_pkt_sequencer", this);
     //Method 1
     uvm_config_wrapper::set(
			      .cntxt(this),
			      .inst_name("*.run_phase"), //which exactly path
			      .field_name("default_sequence"),
			      .value(pkt_sequence::type_id::get())
    //Method 1
   endfunction // build_phase
      super.run_phase(phase);
	    //Method 2
// 	    m_seq  = pkt_sequence::type_id::create("m_pkt_sequence", this);
// 	    m_seq.start(m_seqr);
	    //Method 2
	    #10;
	    packet req;
	    m_seqr.get_next_item(req);
	    `uvm_info(get_type_name(), $sformatf("%s",req.sprint()), UVM_LOW)
      join
   endtask // run_phase
   `uvm_component_utils(test1)
   function new(string name="test1", uvm_component parent);
      super.new(name, parent);
endclass // test1
   run_test("test1");
I have 3 questions about this:
1.When I use Method 1(set default_sequence) to start a sequence, in pre_body()/post_body(), if_branch get executed. However, when I use Method 2(sequence start sequencer) to start a sequence, in pre_body()/post_body(), else_branch get executed. In other words, method 1 starting_phase is non-null object; method 2 starting_phase is null object. Why this cause starting_phase to behave differently?
2.What the exact path when I choose Method 1 to set default_sequence? Is there an easy way to get that exact full path?
.cntxt(this),
.inst_name(“*.run_phase”), //what exactly path???
.field_name(“default_sequence”),
*3.Why in the end, I got a PH_TIMEOUT UVM_FATAL? How to call item_done() in sequence body()?
UVM_FATAL UVM1.1d/sv/src/base/uvm_phase.svh(1265) @ 9200000000000: reporter [PH_TIMEOUT] Default timeout of 9200000000000 hit, indicating a probable testbench issue
  1. The variable starting_phase is only set when using the default_sequence method of starting a sequence. See uvm_sequence_base.svh and uvm_sequencer_base.svh for further clarification. If you are starting the sequence as part of your test, you should set starting_phase manually.
  2. You should never use the default_sequence method to start a sequence as it is deprecated. Always start the sequence as part of your test.
  3. Your test never completes because you don’t call item_done() for req.
In reply to cgales:
Cagales, thanks for your reply.
For Question1, your answer is fair enough. And by set_starting_phase/get_starting_phase, I can make it. This is the solution if I am using UVM1.2. But if I stick on UVM1.1d, do you have any other solution for starting_phase issue when a sequence gets started manually?
For Question2, your answer is ok but not so clear. If you can point out the path of the default_sequence, that would be good.
For Question3, could you give me a hint to call item_done to eliminate this fatal?
I really appreciate that I learn a lot from those questions.
