I my UVM environment, when i am using non-blocking assignments(NBA) in driver it is supporting but when I use it in scoreboard it is giving an error. Why so?
Why NBA is supported in driver and not in scoreboard?
With regards,
Tarun
With regards,
Tarun
In reply to perumallatarun:
It would help to show the error message and the statement causing the error.
SystemVerilog has restrictions on what can be assigned using an NBA based on a number of different things. No NBA’s to
So you also need to show us how the variable you are trying to do an NBA is declared.
I got the mistake.
Thank you Dave.
