I am studying uvm register layer and observed several times that uvm_reg_field is used as random variable on the customer site.
I don’t have much understanding for uvm register layer, so I wonder why it is always random variable.
I’ve tried to find the answer on web and uvm user guide, but I didn’t find.
It is upto you.
If you want to randomize those fields then you can declare as rand if not it is also ok.
However, important is you can randomized those fields only if you set is_rand = 1 in configuration method.
// Reference uvm_reg_field.svh.
791 function void uvm_reg_field::configure(uvm_reg parent,
792 int unsigned size,
793 int unsigned lsb_pos,
794 string access,
795 bit volatile,
796 uvm_reg_data_t reset,
797 bit has_reset,
798 bit is_rand,
799 bit individually_accessible);
842 if (!is_rand)
843 value.rand_mode(0);
Most of times RAL model is generated by automatically via tool/script.
So, tool/script you were using might considering rand always at declaration time and control of randomization enable or not via is_rand at configuration time.
