why in uvm only build phase having super.build phase,for connect phase why we didnt use super.connect phase ?
In reply to lalithjithan:
All _phase()s have a super.phase(), it just that the build_phase() is the only one that has functionality within it. You need to call uvm_component::build_phase() if you use any the the uvm_field* macros, and we strongly recommend against using those macros.
Hi Dave, so do u mean that we just only need to super.build_phase in the build phase when extending uvm_component? because, there are no functionality in other phase in the uvm_component. Am i correct?
In reply to timag:
You only need to call super.build_phase if you use the UVM field macros.
