Why does using a generic interface port (without modports) allow both dut0 and dut1 to drive data and enable without error, while using modports enforces directionality and prevents such assignments?
interface myBus;
  logic clk;
  logic rst;
  logic [7:0] data;
  logic enable;
  modport dut0 (input clk, rst, enable, output data);
  modport dut1 (input clk, rst, data, output enable);
endinterface
module dut1 (interface  _if);
  always @(posedge _if.clk or posedge _if.rst) begin
    if (_if.rst) begin
      _if.data <= 8'b0;
      _if.enable <= 1'b0;
    else begin
      _if.data <= 8'hAA;
      _if.enable <= 1'b1;
module dut0 (interface _if);
    if (_if.rst) begin
      _if.data <= 8'h0;
      _if.enable <= 1'b0;
    else begin
      _if.data <= 8'hAB;
      _if.enable <= 1'b1;
`include "interface.sv"
`include "dut0.sv"
`include "dut1.sv"
module tb;
  myBus _if();
  dut0 d0 (._if (_if.dut0));
  dut1 d1 (._if (_if.dut1));
    _if.clk = 0;
    _if.rst = 1;
    #10 _if.rst = 0;
  always #5 _if.clk = ~_if.clk;
    $monitor("Time=%0t | data=0x%h | enable=%b", $time, _if.data, _if.enable);
    #50 $finish;
and output of this code
Output : -
Time=0 | data=0x00 | enable=0
Time=15 | data=0xaa | enable=1
$finish called from file “testbench.sv”, line 20.
$finish at simulation time 50
This output i expect also because in generic interface allows dut0 and dut1 take anything to input and output
but in this interface code
module dut0 (myBus _if);
    if (_if.rst) begin
      _if.data <= 8'h0;
      _if.enable <= 1'b0;
    else begin
      _if.data <= 8'hAB;
      _if.enable <= 1'b1;
module dut1 (myBus _if);
    if (_if.rst) begin
      _if.data <= 8'b0;
      _if.enable <= 1'b0;
    else begin
      _if.data <= 8'hAA;
      _if.enable <= 1'b1;
this is eda link : - EDA Playground
Output : -
this output i am not expecting i am expecting error(Error-[MPCBD] Modport port cannot be driven
dut0.sv, 5
dut0, “_if.enable”
Port ‘enable’ of modport ‘dut0’ has been restricted as an input port. Input
ports cannot be driven.)
that you can’t assign enable in duto and data in dut1 because they are input in modport.
