I keep getting a warning that the coverpoint gets empty coverage bins for the odd and even bins.
** Warning: (vsim-8858) After processing coverbin with/set expression, the values list associated with scalar bin ‘odd’ in Coverpoint ‘m_addr’ of Covergroup instance ‘’ has converged to empty list. The bin will be taken out of coverage calculation.
** Warning: (vsim-8858) After processing coverbin with/set expression, the values list associated with scalar bin ‘even’ in Coverpoint ‘m_addr’ of Covergroup instance ‘’ has converged to empty list. The bin will be taken out of coverage calculation.
Why am I getting empty coverbins with this covergroup? Am I mixing up types?
I think your m_addr is cover_point_identifier, not a coverpoint signal.
cover_point ::= // from A.2.11
[ cover_point_identifier : ] coverpoint expression [ iff ( expression ) ] bins_or_empty
covergroup cgp;
m_addr : coverpoint address {
bins odd = address with {item % 2 == 1};
bins even = address with {item % 2 == 0};
endgroup
In reply to ce_2015:
covergroup cgp;
endgroup
Your reply would make sense but for the fact that the warning is issued for the odd bins also (which doesn’t use the ‘m_addr’ for its bins definition).
As I have simulated more, it appears that my tool has a built-in fail-safe warning if the address range is too large. Sorting the 2^21 addresses into odd and even bins is time consuming so I have had to explore other options.
