I have the following test code:
module test;
function automatic bit check_process;
if ( process::self() != null)
$display("can get a process in static initializer!");
return 0;
bit x = check_process();
In EDAPlayground all 4 simulators printed out “can get a process in static initializer!”.
Systemverilog initializes those variable before any initial or always procedures. Why does a process exists there ?
In reply to robert.liu:
This is an area where some tools have diverged from the LRM. According to the LRM section 9.5 Process execution threads, a static initialization does not create a process, nor does a continuous assignment. That is why section 13.4.4 Background processes spawned by function calls does not allow fork/join_none from anything but a process created by an initial or always block.
But there must be some kind process for executing static initializations. Some tool have lumped all of those initializations into a single process. Others have created a process for each initialization. The following code executes 4 different ways for each of the 4 simulators on EDAPlayground.
static process previous;
if ( process::self() != null) begin
if (previous != process::self())
$display("different self");
previous = process::self();
return 0;
bit y = check_process();
bit z = check_process();
wire w = check_process();
initial #10 $display("The end");
final x = check_process();
final y = check_process();
Thanks Dave. That’s interesting. New knowledge learnt here.
I changed the code to print clearer message:
module test;
function automatic bit check_process(string prefix);
static bit previous_valid;
$display(prefix, " can get a process in static initializer!");
if (previous_valid && previous != process::self())
$display(prefix, " different self");
previous_valid = 1;
return 0;
bit x = check_process("bit x");
bit y = check_process("bit y");
bit z = check_process("bit z");
wire w0 = check_process("wire w0");
wire w1 = check_process("wire w1");
final x = check_process("final x");
final y = check_process("final y");
