When creating the described task below within an interface, I get a compilation error when declaring and initializing a local automatic variable x before allocating a dynamic array that has already been declared. Here is an example of what I attempted at first:
interface example();
logic data[]
task example_task(int length);
data = new[length];
automatic bit x = 0;
endtask: example_task
endinterface: example
After learning more about default lifetime allocations and researching syntax for tasks, I switched the allocation and initialization before almost giving up and it fixed the issue.
logic data[]
data = new[length];
My question is, why does switching these two lines of code impact how the compiler sees it. Is there a reference into where variables need to be declared / initialized within a task? Thanks. *Edited
