In reply to pghosh:
See my example above from November 20, 2013 at 10:35 am
Basically, since the interface is “virtual” and not physically real, you can connect it to any real physical interface at a later stage. Think of it as a power plug to your toaster; that “plug” is really useless because it does not connect to a power 110 or 220 power source. However, during the fabrication of the toaster, you create a cord and a power plug without knowing which socket it will be connected to. Therefore, until it is connected to a “real” socket, you can tune to the toaster and the design of that plug (e.g., 3 plug, 2 plug, USA design, European design).
- Verification Horizons - March 2018 Issue | Verification Academy
- SVA: Package for dynamic and range delays and repeats | Verification Academy
FREE BOOK: Component Design by Example
… A Step-by-Step Process Using VHDL with UART as Vehicle
http://systemverilog.us/cmpts_free.pdf
