While randomizing 3 values, if one value repeat for 2 times, then other two values should repeat for one time
The variable rand_i is having 10 values(1,2,3,4,5,6,7,8,9,10), I want to write a constraint
1,2,3 → among this 3 values if one value repeated for 3 times then other two values should repeat two times
4,5 → any one value should repeat for 2 times
6,7 → any one value should repeat for 2 times
8 → should repeat for 2 times
9,10 → any one value should repeat for 2 values
In reply to bsivakumar:
The title question does not match the requirements in the body of your post. Can you clarify. Also, be “repeat” do you mean consecutively, or within a cycle of values?
Can you give some examples of expected values that would meet the constraints?
Hi dave,
Thanks for your response.
we have two scenarios,
The first scenario is consecutive and the result will be like below :
first_randomization → 1,1,2,2,2,3,3, 4,5,5, 6,6,7, 8,8, 9,10,10
second_randomization → 1,1,1,2,2,3,3, 4,4,5, 6,7,7, 8,8, 9,9,10
The second scenario is within a cycle of values and the result will be like below :
first_randomization → 1,2,3,4,8,6,3,7,9,4,5,7,8,4,3,9,10,1,2
class array;
  rand int is_cons;
  int rand_i[18];
  int fixed_arr1[14] = '{1,1,2,2,3,3,4,5,6,7,8,8,9,10};
  rand int part_arr[4];
  int fixed_arr2[4][] = '{'{1,2,3},'{4,5},'{6,7},'{9,10}};
  constraint c1 { foreach(part_arr[i]) part_arr[i] inside {fixed_arr2[i]}; }
     rand_i = {fixed_arr1,part_arr};
     if(is_cons)rand_i.sort();
     else rand_i.shuffle();
module tb;
  array a;
    a=new();
    repeat(10)begin
    	a.randomize() with {is_cons==1;};
        $display("%0p",a.rand_i);
    $display("\n\n");
    repeat(10)begin
    	a.randomize() with {is_cons==0;};
//OUTPUT:
'{1, 1, 2, 2, 2, 3, 3, 4, 4, 5, 6, 7, 7, 8, 8, 9, 10, 10}
'{1, 1, 2, 2, 3, 3, 3, 4, 4, 5, 6, 7, 7, 8, 8, 9, 9, 10}
'{1, 1, 2, 2, 3, 3, 3, 4, 4, 5, 6, 7, 7, 8, 8, 9, 10, 10}
'{1, 1, 2, 2, 3, 3, 3, 4, 5, 5, 6, 6, 7, 8, 8, 9, 9, 10}
'{1, 1, 2, 2, 2, 3, 3, 4, 5, 5, 6, 6, 7, 8, 8, 9, 10, 10}
'{1, 1, 2, 2, 2, 3, 3, 4, 5, 5, 6, 6, 7, 8, 8, 9, 9, 10}
'{1, 1, 1, 2, 2, 3, 3, 4, 5, 5, 6, 7, 7, 8, 8, 9, 10, 10}
'{1, 1, 2, 2, 3, 3, 3, 4, 5, 5, 6, 7, 7, 8, 8, 9, 9, 10}
'{1, 1, 2, 2, 2, 3, 3, 4, 5, 5, 6, 7, 7, 8, 8, 9, 10, 10}
'{1, 1, 1, 2, 2, 3, 3, 4, 5, 5, 6, 6, 7, 8, 8, 9, 9, 10}
'{1, 2, 3, 8, 9, 6, 10, 5, 5, 1, 9, 2, 7, 3, 7, 4, 8, 1}
'{6, 2, 4, 6, 3, 2, 7, 8, 8, 10, 1, 3, 10, 5, 5, 2, 1, 9}
'{5, 3, 3, 9, 1, 10, 8, 2, 1, 7, 2, 8, 4, 2, 6, 4, 10, 7}
'{3, 4, 1, 4, 10, 2, 2, 3, 8, 5, 7, 9, 2, 7, 1, 6, 8, 10}
'{5, 1, 7, 6, 5, 6, 3, 8, 8, 9, 4, 10, 2, 2, 9, 3, 1, 2}
'{9, 10, 2, 1, 8, 1, 7, 3, 6, 2, 4, 9, 5, 3, 8, 6, 2, 5}
'{7, 3, 10, 9, 7, 8, 2, 1, 4, 10, 3, 1, 8, 1, 5, 5, 6, 2}
'{1, 1, 9, 8, 3, 10, 2, 3, 6, 5, 4, 2, 3, 8, 7, 7, 5, 9}
'{8, 6, 7, 5, 3, 2, 9, 1, 10, 4, 5, 8, 7, 10, 2, 1, 2, 3}
'{3, 4, 10, 7, 1, 5, 1, 3, 1, 6, 5, 2, 2, 8, 8, 9, 9, 6}
