Where to put directed tests in a structured class-based systemVerilog testbench?
I’m relatively new to verification using systemVerilog having come from a directed-testing based verilog background.
If I have a modular class-based systemVerilog testbench designed for random testing, that does not use UVM but uses UVM-like architectures with an environment, agent, generator, driver, monitor, scoreboard etc that utilizes transaction classes which are normally randomized in the generator, how do I adapt this testbench to then run directed tests where a very specific sequence of inputs (rather than random) is required?
Is there a general recommendation as to how to do this? Do I write a completely new testbench that throws out all the generator, driver stuff or can a directed test logically reside inside one of the standard classes - e.g. should I create a new task inside the driver to drive the necessary sequence? This might be done by creating a derived version of the driver where it’s main task is replaced by a directed test. Would this be a logical approach or is there a standard well recognised way of adapting a testbench designed for random testing to make it capable of driving very specific and sometimes long sequences of directed inputs?
Any thoughts on this welcome!
In reply to Duke Lamonty:
If you were using the UVM, I could show you how to use its class factory to override the sequence with constraints that match your directed test scenarios. But since you have created your own class based methodology, we cant help you.
Ok. Thanks Dave. I’m starting to get my head around UVM. I’ll revisit the topic when I get a bit further with that.
