could you please let me know when the expression position & vector is checked in the below code. is it only when the constructor of cover group called or each time when ever sample function of cover group called.
module coverx;
bit clk, smpl;
logic[3:0] a=4'b1XZ0;
initial forever #10 clk=!clk;
always @ (posedge clk) begin : aly
smpl <= 1'b1;
t_cg.sample(); // <-----------------------------The sample of t_cg
@ (posedge clk);
smpl <= 1'b0;
a=4'b0010;
end : aly
// If cp_a coverage is ture, then an X or a Z was observed
cp_aXZ: cover property(@ (posedge clk iff smpl) $isunknown(a));
ap_aNoXZ: assert property(@ (posedge clk iff smpl) $isunknown(a)==0);
function automatic int countbits(logic[3:0] v);
automatic int s=0;
for (int i=0; i<= 3; i++) begin
if (v[i]===1'bX || v[i]===1'bZ) begin
s=s+1;
$display("is X or Z");
$display("%t v=%b, countbits=%d", $time, v, s);
return s;
endfunction : countbits
covergroup a_is_x_cg;
type_option.merge_instances = 0;
option.per_instance = 1;
option.get_inst_coverage = 1;
cp_unknown: coverpoint $isunknown(a)==0;
// ($isunknown ==0) i.e. true then no X or Z
cp_with_countbits: coverpoint countbits(a) ==0 ;
cp_with_countbits_axz: coverpoint $countbits (a, 'x, 'z) ==0; // 1800-2012
// ($countbits (a, 'x, 'z) ==0) then no X or Z
endgroup
a_is_x_cg t_cg = new; // instantiation of covergroup <<---------------------------
endmodule : coverx
