Dear All,
I’m trying to understand the Virtual keyword.
I found a virtual keyword with some keyword such as virtual function, virtual class, virtual interface.
Would you please let me know when do I need that Virtual keyword with example?
for example ,
I came across some example when I googling.
//abstract class
virtual class packet;
bit [31:0] addr;
function display();
$display("Addr = %0d",addr);
module virtual_class;
packet p;
p = new();
p.display();
As you can see above example, there was used in class.
But I didn’t get it exactly when I do need it.
In reply to sylee:
That could should have produce an error, you cannot construct a virtual/abstract class.
Please see
https://verificationacademy.com/content/re-use-abstract-class-0
The reason for the virtual keyword instead of using abstract was to keep the number of new keywords down, and virtual tends to mean something that appears but is not quite there.
Thanks, I thought that the example to show the reason of why we use abstract class.
but not much I can get information from that example, so Would you please give me any snippet code? for understand ?
In reply to sylee:
Have you looked at any of the links I gave you? Especially the first one.
Of course, I’ve already seen before,
Test1.
bit [31:0] addr;
function display();
class child_class extends packet;
function display();
super.display();
child_class p;
p = new();
p.addr = 10;
p.display();
VS
Test2
class packet;
bit [31:0] addr;
function display();
function display();
super.display();
child_class p;
p = new();
p.addr = 10;
p.display();
I don’t know but I found some resolve solution for my question.
Might be I need to make some derived class by using “extends” when I use “virtual”.
It seems work. but I still didn’t get it exactly why we do use the “virtual” keyword.
One more, When I remove the virtual keyword in Test2 code, but there’s nothing different.
virtual class/abstract class:
if you are declaraing a class as virtual then it means that class can’t be instantiated. virtual class are used to implement any base class which can only be extended. as you have done in your test1 where you define a virtual class and then derived a child class from that base class.
In reply to Mohan Shyam:
Now, I’m getting started to understand about “virtual” keyword. Would you please let me know which part do you indicate about “instantiated” in the Test1 or Test2?
One more, what If I use that “Virtual” to function not class,
class A ;
virtual function void disp ();
$display(" Non-Virtual from A ");
virtual function void vdisp ();
$display(" Virtual from A ");
class EA extends A ;
$display(" Non-Virtual from EA ");
$display(" Virtual from EA ");
module main ;
function void disp( EA a);
a.disp();
a.vdisp();
A my_a;
EA my_ea;
initial
my_a = new();
my_ea = new();
disp(my_a);
disp(my_ea);
What am I supposed to do to use EA not A as the below?
a.disp();
a.vdisp();
