The last argument to `uvm_info needs to be one of the verbosity enumerations or a decimal value. Typically this would be UVM_LOW, UVM_HIGH, etc. UVM_INFO is not a valid option here.
Hi jcraft, I see. Now I did go and change the last argument to UVM_LOW or UVM_NONE, yet the error message persists. I looked up `uvm_info to confirm that there are indeed 3 arguments and that i’m not crazy… any other possible causes for this?
`uvm_info needs three arguments which are ID, message & verbosity. ID & message are of string data type & verbosity is an enumerated data type that takes values like UVM_NONE =0, UVM_LOW =100, UVM_MEDIUM =200, UVM_HIGH=300, UVM_FULL=400. Based on the importance of the message i.e., whether the message used is for debugging or its a report message, different verbosity will be given to the info messages. For debugging messages higher value of verbosity should be given & for reporting messages to lower values should be given so that we can filter the debugging messages when it’s not required
Whereas the other reporting macros with severity error, warning & fatal takes only two arguments ID and message which are of the string data type. The verbosity for these severities(error, warning & fatal) is by default UVM_NONE as these messages should not be filtered out.
`uvm_info("ID","message", int verbosity)
`uvm_warning("ID","message")
`uvm_error("ID","message")
`uvm_fatal("ID","message")
In your code, you might be passing three arguments for warning, error, or fatal message. Kindly check the code once again.
I am compiling a file that was working fine with vcs simulator. When I am trying with Questa, I am getting “Number of actuals and formals does not match in function call” error for all 'uvm_error, uvm_fatal calls. Ex: uvm_error (“FILE_OPEN”, “Unable to open AA file for reading”)
`uvm_fatal(“INITIALIZE, " values has not been found”)
I have uvm 1.2 pkg, while compiling it says importing pkg uvm_pkg uvm-1.1d Built-in
From the error message which says when compiling uvm_info and uvm_fatal … so are you/somebody redefining these macros with more or less parameters by any chance??
No the " exist in the code. I have misplaced it while posting here. Sorry
I was assuming this. Again, your problem will be caused by an erro prior t the uvm_reporting.
I’d include directly befor the reprting macro any stupid error in your code. See what happens.
