What is UVM Sequence Library Means?
Hi Verification Academy Forum Desk,
Could you please explain me in brief what does UVM Sequence Library mean? What exactly it contains and what is its significance?
Check out the Cookbook here.
Just a set/family of sequences could be disposed by particular UVC. A simple example:
usb_agent.sv
usb_drive.sv
usb_sequencer.sv
usb_sequence_lib.sv
The use_sequence_lib.sv may contain following individual sequence classes:
class reset_seq extends uvm_sequence ;
class write_tran extends uvm_sequence ;
class read_tran extends uvm_sequence ;
All of above sequences could be disposed by usb_sequencer and usb_driver to achieve your specified purpose.
