What is the right methodology to write a register check?
Hi,
The thing is that in my suggested example i don’t write in the register from my sequence. It is the Device under test which internally update the status of the register to an specific a defined/constant value X (it could also be a calculated value) after the sequence of event from AHB and AXI bus are performed.
In any case, the question is about if you check the status of the register from the sequence or from a scoreboard (a general component that only looks on the bus but not from the stimulus generator sequence).
If i understand you well, then you suggest to perform the check and read the register value direct from the sequence, using the UVM register model API. (i.e. option two but using the register model API)
Best regards,
Jonathan
