What is the difference between pre randomization and post randomization methods?
what is the difference between pre randomization and post randomization methods???
When you call the randomize() method on a SV class, then the following methods are called in order:
pre_randomize()
randomize()
post_randomize()
A user can overload the pre_randomize() and post_randomize() methods but not the randomize() method. The pre-randomize() method is used to set up variables that are used in constraints during the randomize() method. The post-randomize() method is used to calculate values based on the results of the randomize() method.
In reply to mperyer:
thank you very much…
In reply to swamym938:
When you randomize the object, it go through below sequence of method execution. pre/post_randomize method are optional.
  • pre_randomize()
  • randomize
  • post_randomize()
class abc;
  rand bit [3:0]  data;
  rand bit dummy_bit;
  constraint c_data { data >= 3; data <= 6; }
  //display function get executed during randomization
  constraint c_disp { dummy_bit == display(); }
  function void pre_randomize ();
    $display ("before randomization");
  function bit display();
    $display("during randomization");
    return 1;
  function void post_randomize ();
    $display ("after randomization");
program my_prg;
    abc a1;
    a1 = new();
    a1.randomize();
endprogram : my_prg
after randomization
