Please explain me the difference between export_port and import_port and tell me where i can use only export port not import port and vice versa.
Thanks & Regards
Sachin
Thanks & Regards
Sachin
A port has methods which are implemented in an export.
When you connect a port to an export and call a method, then the place where the method is executed is in the export.
See chapter 2 of the UVM users guide, especially section 2.3 for examples and more explanation.
In reply to mperyer:
Thanks for the reply. But i want to know the difference between export and import. As per my understanding both are same. If there is some differnence the please explain me the difference.
Regards
Sachin
