What is the between the use of typedef with enum and simple enum declaration ?
In reply to shankar_srininvasan:
You need a typedef if you want more than one variable to share the same enumerations.
typedef is used to declare user defined types, so by declaring a typedef enum you are creating a new data type which can be used to create variables now. EX :
enum {RED, GREEN} col, col1; // Without typedef
typedef enum {RED, GREEN} color; //With typedef
color col, col1;
Thanks so much for your valuable response @dave and @rohitk
