What is Difference between downcasting and upcasting Systemverilog?
Hi Everone ,
 I was googling for Definition of upcasting and down-casting in SV. the search result is making confuse ? Please clear this concept.
Regards
kbkdec15
In reply to kbkdec15:
Hi kbkdec15,
I hope by this time you must have found the answer for this.
We take the advantage of inheritence and polymorphysm of SV classes here. Upcasting is where we assign the derived class’s handle to base class. The advantage is obvious: reusability.
class base;
  int a = 5;
class child extends base;
  int b = 6;
    base base_h;
    child child_h;
    child_h = new();
    $cast(base_h, child_h); // same as: base_h = child_h;
    $display(child.a); // a is base's property
Now downcasting is opposite of the above; assigning the base class handle to child class handle. But this will not work until the base class handle already refers to child class handle. When an array of base class is present, where it is filled with different child class handles, this downcasting comes handy. Check the following code (copied from casting - Does SystemVerilog support downcasting? - Stack Overflow):
class animal;
  function void eat();
class dog extends animal;
  function void bark();
    $display("woof");
class cat extends animal;
  function void meow();
    $display("meow");
module test;
    dog a_dog = new();
    cat a_cat = new();
    animal animals[$];
    animals.push_back(a_dog);
    animals.push_back(a_cat);
    foreach (animals[i]) begin
      dog another_dog;
      animals[i].eat();
      if ($cast(another_dog, animals[i])) begin
        $display("Found a dog!");
        another_dog.bark();
Hope that helps.
-mpattaje
In reply to mpattaje:
The casting in the first example is redundant as the child already have the variable a, as it inherits all properties of the base class. So, if the casting wasn’t done, still the access of child_h.a is valid.
Upcasting is basically used with virtual methods, where you want to access base class methods using the variable of the superclass. Below example will clarify the idea:
class BasePacket;
  int A =1;
  int B = 2;
  function void printA;
  $display("BasePacket::A is %d", A);
  endfunction : printA
  virtual function void printB;
  $display("BasePacket::B is %d", B);
  endfunction : printB
  endclass : BasePacket
class My_Packet extends BasePacket;
  int A = 3;
  int B = 4;
  $display("My_Packet::A is %d", A);
  endfunction: printA
  $display("My_Packet::B is %d", B);
  endclass : My_Packet
module main;
  BasePacket P1 = new;
My_Packet P2 = new;
P1.printA; // displays 'BasePacket::A is 1'
P1.printB; // displays 'BasePacket::B is 2'
$case(P1,P2) // same as P1 = P2..  P1 has a handle to a My_packet object
P1.printB; // displays 'My_Packet::B is 4' – latest derived method
P2.printA; // displays 'My_Packet::A is 3'
P2.printB; // displays 'My_Packet::B is 4'
endmodule: main
