I encounter this syntax when I was doing a UVM-1.2 lab, the document says it is helpful for debugging because it will print the method name and file context , but I just wonder what the “%m” mean ?
In reply to zhangmiao:
If you are learning SystemVerilog or UVM, you should have a copy of the IEEE SystemVerilog Language Standard for reference.
Table 21.2 - Escape sequences for format specifications states that %m or %M will display the hierarchical name.
In reply to cgales:
Thank you for bothering to answer this question, but I only have version 1800-2012 of IEEE Standard and I find that information, though.
In reply to Marina:
The link above will get you the 2017 version. Then look for section 21.2.
