Hi everyone,
I am a newbie on UVM verification and trying to verify for a WDT design by UVM evironment.
WDT Description:
- Inside a WDT, it has a clock mux between two external clocks(clk1 and clk2) to iclk based on the control of clk_sel signal. If clk_sel =1 iclk =clk1, otherwise iclk = clk2.
- if wr_en=0 It writes the configured data into WDT. wr_en=1 it reads out data from WDT register
- When wt_en=1, the counter will count up, and when it reaches the timer set, wt_int interrupts for a specified periods. the timer set and interrupt periods of wt are controlled by timer_sel[1:0] and interrupt_len[1:0]
- If wt_rst =1 → WDt reset
Could anyone help me on the basic steps what I need to do for this verification.
For the clock mux case, how uvm helps me to check the iclk whether it’s right to the spec when I control clk_sel.
Any help I highly appreciate it
Stephan
