Want to generate array of one hot numbers using system Verilog constraints
I want to generate 9 one hot numbers each with 9 bit length in system Verilog constraints . But the below code is generating all 0s. Any idea whats going wrong?
class unique_elements;
  rand bit [8:0] my_var[9];
  constraint my_var_c{
    foreach(my_var[i])
      $countones(my_var[i]) == 1;
      unique{my_var};
  function void display();
    foreach(my_var[i])
      $display("my_var = %p",my_var[i]);
program unique_elements_randomization;
  unique_elements pkt;
    pkt = new();
    pkt.randomize();
    pkt.display();
endprogram
class Example;
	rand bit[8:0] num;
	bit[8:0] num_q[$];
	constraint c1 {$countones(num) == 1;}
	constraint c2 {!(num inside {num_q});}
	  num_q.push_back(num);
		$display("num = %b", num);
module TB;
	Example E;
		E = new();
		repeat(9) begin
			assert(E.randomize());
You have run into a tool specific problem. out of 4 tools on www.edplayground.com give you the desired results.
