Hi Gaurav,
You can use the same uvm_event which you have mentioned .
You can get the event with the help of uvm_event_pool, the sharing of the event happens with respect to the name with which you have set your clock event.
Please find the code snippet below.
example:
class my_sequence extends uvm_sequence;
//factory registration
//other stuff
uvm_event_pool my_event_pool;
uvm_event clk_event;
clk_event = new();
my_event_pool = uvm_event_pool::get_global_pool();
`uvm_info(get_full_name(),my_event_pool.get_type_name(),UVM_HIGH);
task body();
clk_event = my_event_pool.get("CLOCK EVENT");//this clock event will be triggered and set in the event pool with the same name in some other place where you have the access to the virtual interface handle.
clk_event.wait_trigger;
I hope this helps in solving your problem.
Thanks,
Neith
