i have the following array, and i want to unblock on any change in any array element.
logic[14:0] array_of_vals[10:0];
@(array_of_vals);
//Do something
Will this work?
@(array_of_vals);
//Do something
Will this work?
In reply to dannyg:
Not according to the LRM
Event expressions shall return singular values. Aggregate types can be used in an expression provided the expression reduces to a singular value. The object members or aggregate elements can be any type as long as the result of the expression is a singular value.
In reply to dannyg:
Hi ,
Here is what you could do ::
SOLUTION 1 ::
logic [14:0] array_of_vals [10:0];
@(array_of_vals[0],array_of_vals[1],array_of_vals[2],.....,array_of_vals[10]); // Tedious so its better to write a define Macro
$display("Change Received"); // Will get This Output
#10; array_of_vals[5] = 10;
SOLUTION 2
logic[10:0] [14:0] array_of_vals;
@(array_of_vals);
Regards,
AGIS
