I want to run a certain function (for instance coverage sampling), and I need to run it at main phase - meaning after configuration phase.
How can I trigger my function to run once sometime at run phase?
Thanks.
Thanks.
In reply to zahibe:
You have conflicting requirements. You say you want to run your function at the main_phase, and then you say you want to run once in the run_phase.
You can call any function at the beginning of each phase. There is no need to wait for it.
call_function_you_want_here();
Maybe there is more to your issue you haven’t stated.
