*W, ENUMERR This assignment is a violation of SystemVerilog strong typing rules for enumeration datatypes
Hi Dave,
Thanks for the suggestion.
I did some changes on the declaration and the warning has gone. However, there’s a new warning.
It says that “Disallowed virtual interface hierarchical reference object type” pointint to this code in
the scoreboard:
s_vif.spi_mode <= ADDRESSABLE_MODE;
The changes I did are below:
// spi_die_env_pkg
package spi_die_env_pkg;
  typedef enum {ADDRESSABLE_MODE, ROUND_ROBIN, DAISY_CHAIN} spi_mode_e;
  import spi_agent_pkg::*; // spi_if is here and it is using spi_mode_e
  import sw_data_agent_pkg::*; // sw_data_if is here and it is using spi_mode_e
  // Environment components included here
endpackage : spi_die_env_pkg
`include "spi_if.sv" // Note that this interface is outside the package
package spi_agent_pkg;
  typedef virtual spi_if spi_vif;
  // spi_agent components included here
endpackage : spi_agent_pkg
`include "sw_data_if.sv" // Note that this interface is outside the package
package sw_data_agent_pkg;
  typedef virtual sw_data_if sw_data_vif;
  // sw_data_agent components included here
endpackage : sw_data_agent_pkg
// spi_if
interface spi_if();
  spi_mode_e spi_mode = ADDRESSABLE_MODE;
endinterface : spi_if
// sw_data_if
interface sw_data_if();
endinterface : sw_data_if
If I remove the typedef in the spi_die_env_pkg, I’m having a compile error saying that the scoreboard can’t see spi_mode.
If I remove the typedef in the spi_agent_pkg, I’m having a compile error saying that the monitor can’t see spi_mode.
If I remove the typedef in the interface, I’m having a compile error saying that the interface can’t see spi_mode_e.
