HI :
in the UVM cookbook session SEQ/VIRTUAL : virtual seq that run on vir seqr
the example shows:**
class v_seq extends uvm_sequence #(uvm_sequence_item);
vir_seqr v_sqr;
bus_sqr bus;
gpio_sqr gpio;
task body();
if ( ! $cast(v_sqr, m_sequencer) begin
`uvm_error(get_full_name, " virtual sequencer pointer cast failed");
bus = v_sqr.bus;
gpio= v_sqr.gpio;
I was wondering if i can use macro `uvm_declare_p_sequencer(…) instead. i am not sure what the cons for doing so. To me, it makes more sense to do connection only in TB components side.
There’s no real difference between the code on the cookbook page and the code in the p_sequencer macro:
define uvm_declare_p_sequencer(SEQUENCER) \ SEQUENCER p_sequencer;\ virtual function void m_set_p_sequencer();\ super.m_set_p_sequencer(); \ if( !$cast(p_sequencer, m_sequencer)) \ uvm_fatal(“DCLPSQ”,
$sformatf(“%m %s Error casting p_sequencer, please verify that this sequence/sequence item is intended to execute on this type of sequencer”, get_full_name()))
The more explicit code in the cookbook example is designed to allow users to see what is going on, whereas using the p_sequencer macro hides the code and would require an explanation of the macro and the p_sequencer.
The code shown on the page is also for a virtual sequence base class. Other virtual sequences would inherit from this and simply call super.body() in order to get the sub-sequencer handles assigned.
For the above $cast to work, m_sequencer which is the generic handle for uvm_sequencer should have been cast earlier to sequencer handle of type virtual_sequencer. Where is this getting done? Is it automatically getting assigned when I construct the object for virtual_sequencer? How does it work?
