Hello, I am getting the above error for my uvm_subscriber class that I wrote as following.
`uvm_analysis_imp_decl(_bfm2dut_change)
class checker_subscriber extends uvm_subscriber;
uvm_analysis_imp_bfm2dut_change#(setup_pcie_pkg::dut2bfm_hdr_trans, checker_subscriber) bfm2dut_change_ap;
`uvm_component_utils(checker_subscriber)
extern function new(string name = "checker_subscriber", uvm_component parent = null);
extern virtual function void build_phase(uvm_phase phase);
extern virtual function void connect_phase(uvm_phase phase);
extern virtual task run_phase(uvm_phase phase);
// write function xal2fb
virtual function void write_xal2fb_change(xal2fb_uvc::transaction tr);
xal2fb_uvc::tx_default_data_obj obj;
$cast(obj, tr.tx_data_obj);
`uvm_info("xal2fb PPMSU monitoring", $sformatf("%m"), UVM_LOW)
monitor_xal2fb_pcie_order_check(obj);
endfunction: write_xal2fb_change
endclass : checker_subscriber
