Verification of components containing PHY IP
In reply to DefaultName:
Just because you think your third-party IP’s have been verified doesn’t absolve you from verifying that you are using it correctly.
If you have performance concerns, you might want to replace the PHY on most of your tests with a higher level models that just has the functionality to interact with your DUT.
Probably not the answer you were looking for, but I hope this helps.
