I tried to do assignment of range of bits from one vector to another.
The range might differ, based on another argument to the function called rd_size.
Received next error:
*Error-[NCE] Non-constant expression
The following expression should be a constant.
Expression: _width
Source info: masked_data[orig_addr[3:0]*4 +: _width] = _temp[orig_addr[3:0]4 +: _width];
What elegant way one might use to code it, except moving the last statement of the function into each line of the case?
function bit [127:0] masked_data(input bit[127:0] data_line, input bit[33-1:0] orig_addr, input svt_axi_transaction::burst_size_enum rd_size);
bit[127:0] _temp = data_line;
bit[7:0] _width;
case (rd_size)
svt_axi_transaction::BURST_SIZE_8BIT : _width = 8;
svt_axi_transaction::BURST_SIZE_16BIT : _width = 16;
svt_axi_transaction::BURST_SIZE_32BIT : _width = 32;
svt_axi_transaction::BURST_SIZE_64BIT : _width = 64;
svt_axi_transaction::BURST_SIZE_128BIT : _width = 128;
default : `uvm_fatal(get_name(), "Illegal AXI burst_size!")
endcase
masked_data[orig_addr[3:0]*4 +: _width] = _temp[orig_addr[3:0]*4 +: _width];
endfunction : masked_data
Thanks!
