I want to generate vcd dump for a simulation and I want all signals including signals of submodules under design hierarchy top.d.dut_top.
I am getting some FATAL error in simulaiton when adding following verilog code:
$dumpfile (“test.vcd”)
$dumpvars (0, top.d.dut_top);
I am unable to debug this and moved to do file option
I generated vcd by adding below lines to do file
vcd file test.vcd
vcd add /top/d/dut_top/*
The VCD file is generated successfully. But the dump only has signals at one level of hierarchy only i.e, top.d.dut_top and do not have the signals of submodules below top.d.dut_top hierarchy.
what is the do file command to mention that the vcd file should have dump for all signals, including signal of sub-modules under hierarchy top.d.dut_top. Or else, question is what is equivalent do file command line option corresponding to $dumpvars(0, top.d.dut_top);
Please help.
Regards,
San
