UVMF without Questa
In reply to polyengineer13:
The UVMF base classes and generated code it produces have been tested against other simulators and it should work out of the box. None of the provided Makefiles or scripts that drive the suggested compile and run flows support other simulators, that would be up to you to develop. The changes I’ve seen to make that work are all very straightforward but I don’t have anything concrete to share.
