How do I call/use C++ reference model in UVM environment?
Do I need DPI or SystemC wrapper?
What is the best way to use C++ reference model in UVM ?
In reply to superUVM:
The most efficient way is usually wrapping the C++ in DPI-C calls. However, you need to explain what the architecture of the reference model looks like. Is it just a function call manipulating packets of data? Or is timing involved?
These models are untimed models. Some models will be used in scoreboard/predictor. Some models will be used for stimulus generation and that is where I have not clear on what is the best way to integrate it in UVM environment. Test sequences are used to generate stimulus in UVM but how do I use these c++ stimulus generator models in UVM?
I am trying to find best way to integrate this in UVM.
Use UVM Connect.
Using c++ models in scorboards is quite common. In most of the cases it is quite simple to implement a call of your ref model using the DPI interface.
With respect to the pattern generator it depends for what you are using the c++ genherator. It is necessary to investigate the details. SV/UVM offers you high quality random pattern. Maybe you are using this together with function calls. I’m not sure if UVMConnect is the best solution.
UVMConnect will be additional layer just to take care of c++ pattern generator. Can you not incorporate this C++ pattern generator in sequence similar to use of C++ model in scoreboard?
Yes you can do this, i.e. calling C++ code in your sequence, assebling your data. I said UVMConnect might not be the best solution.
Great! Thanks!
