In reply to verif_learner:
To see why we don’t recommend these macros, see the amount of code these 5 macros expand to, The reason for the _begin/_end macros is they are defining a __m_uvm_field_automation function, and each field expands code as part of that function. The overhead is not just in the generated code, but in all the function calls added by the macros.
//`uvm_object_utils_begin(simple_item)
typedef uvm_object_registry#(simple_item,"simple_item") type_id;
static function type_id get_type();
return type_id::get();
endfunction virtual function uvm_object_wrapper get_object_type();
function uvm_object create (string name="");
simple_item tmp;
tmp = new();
if (name!="") tmp.set_name(name);
return tmp;
endfunction const static string type_name = "simple_item";
virtual function string get_type_name ();
return type_name;
function void __m_uvm_field_automation (uvm_object tmp_data__,
int what__,
string str__);
simple_item local_data__;
typedef simple_item ___local_type____;
string string_aa_key;
uvm_object __current_scopes[$];
if(what__ inside {UVM_SETINT,UVM_SETSTR,UVM_SETOBJ}) begin
if(__m_uvm_status_container.m_do_cycle_check(this)) begin
return;
__current_scopes=__m_uvm_status_container.m_uvm_cycle_scopes;
super.__m_uvm_field_automation(tmp_data__, what__, str__);
if(tmp_data__ != null) if(!$cast(local_data__, tmp_data__)) return;
//`uvm_field_int(addr, UVM_ALL_ON)
case (what__) UVM_CHECK_FIELDS: begin
__m_uvm_status_container.do_field_check("addr", this);
UVM_COPY: begin
if(local_data__ == null) return;
if(!((UVM_ALL_ON)&UVM_NOCOPY)) addr = local_data__.addr;
UVM_COMPARE: begin
if(!((UVM_ALL_ON)&UVM_NOCOMPARE)) begin
if(addr !== local_data__.addr) begin
void'(__m_uvm_status_container.comparer.compare_field("addr", addr, local_data__.addr, $bits(addr)));
if(__m_uvm_status_container.comparer.result && (__m_uvm_status_container.comparer.show_max <= __m_uvm_status_container.comparer.result)) return;
UVM_PACK: if(!((UVM_ALL_ON)&UVM_NOPACK)) begin
if($bits(addr) <= 64) __m_uvm_status_container.packer.pack_field_int(addr, $bits(addr));
else __m_uvm_status_container.packer.pack_field(addr, $bits(addr));
UVM_UNPACK: if(!((UVM_ALL_ON)&UVM_NOPACK)) begin
if($bits(addr) <= 64) addr = __m_uvm_status_container.packer.unpack_field_int($bits(addr));
else addr = __m_uvm_status_container.packer.unpack_field($bits(addr));
UVM_RECORD: if(!((UVM_ALL_ON)&UVM_NORECORD)) begin
__m_uvm_status_container.recorder.record_field("addr", addr, $bits(addr), uvm_radix_enum'((UVM_ALL_ON)&(UVM_RADIX)));
UVM_PRINT: if(!((UVM_ALL_ON)&UVM_NOPRINT)) begin
__m_uvm_status_container.printer.print_int("addr", addr, $bits(addr), uvm_radix_enum'((UVM_ALL_ON)&UVM_RADIX));
UVM_SETINT: begin
bit matched;
__m_uvm_status_container.scope.set_arg("addr");
matched = uvm_is_match(str__, __m_uvm_status_container.scope.get());
if(matched) begin
if((UVM_ALL_ON)&UVM_READONLY) begin
uvm_report_warning("RDONLY", $sformatf("Readonly argument match %s is ignored", __m_uvm_status_container.get_full_scope_arg()), UVM_NONE);
else begin
if (__m_uvm_status_container.print_matches) uvm_report_info("STRMTC", {"set_int()", ": Matched string ", str__, " to field ", __m_uvm_status_container.get_full_scope_arg()}, UVM_LOW);
addr = uvm_object::__m_uvm_status_container.bitstream;
uvm_object::__m_uvm_status_container.status = 1;
__m_uvm_status_container.scope.unset_arg("addr");
endcase end
// `uvm_field_int(data, UVM_ALL_ON)
__m_uvm_status_container.do_field_check("data", this);
UVM_COPY: begin
if(!((UVM_ALL_ON)&UVM_NOCOPY)) data = local_data__.data;
UVM_COMPARE: begin
if(data !== local_data__.data) begin
void'(__m_uvm_status_container.comparer.compare_field("data", data, local_data__.data, $bits(data)));
if($bits(data) <= 64) __m_uvm_status_container.packer.pack_field_int(data, $bits(data));
else __m_uvm_status_container.packer.pack_field(data, $bits(data));
if($bits(data) <= 64) data = __m_uvm_status_container.packer.unpack_field_int($bits(data));
else data = __m_uvm_status_container.packer.unpack_field($bits(data));
__m_uvm_status_container.recorder.record_field("data", data, $bits(data), uvm_radix_enum'((UVM_ALL_ON)&(UVM_RADIX)));
__m_uvm_status_container.printer.print_int("data", data, $bits(data), uvm_radix_enum'((UVM_ALL_ON)&UVM_RADIX));
UVM_SETINT: begin
bit matched;
__m_uvm_status_container.scope.set_arg("data");
if(matched) begin
else begin
data = uvm_object::__m_uvm_status_container.bitstream;
__m_uvm_status_container.scope.unset_arg("data");
endcase end
// `uvm_field_int(delay, UVM_ALL_ON)
__m_uvm_status_container.do_field_check("delay", this);
UVM_COPY: begin
if(!((UVM_ALL_ON)&UVM_NOCOPY)) delay = local_data__.delay;
UVM_COMPARE: begin
if(delay !== local_data__.delay) begin
void'(__m_uvm_status_container.comparer.compare_field("delay", delay, local_data__.delay, $bits(delay)));
if($bits(delay) <= 64) __m_uvm_status_container.packer.pack_field_int(delay, $bits(delay));
else __m_uvm_status_container.packer.pack_field(delay, $bits(delay));
if($bits(delay) <= 64) delay = __m_uvm_status_container.packer.unpack_field_int($bits(delay));
else delay = __m_uvm_status_container.packer.unpack_field($bits(delay));
__m_uvm_status_container.recorder.record_field("delay", delay, $bits(delay), uvm_radix_enum'((UVM_ALL_ON)&(UVM_RADIX)));
__m_uvm_status_container.printer.print_int("delay", delay, $bits(delay), uvm_radix_enum'((UVM_ALL_ON)&UVM_RADIX));
UVM_SETINT: begin
bit matched;
__m_uvm_status_container.scope.set_arg("delay");
if(matched) begin
else begin
delay = uvm_object::__m_uvm_status_container.bitstream;
__m_uvm_status_container.scope.unset_arg("delay");
endcase end
// `uvm_object_utils_end
