UVM Transaction class has two variable rand int a; rand int b; and both variables are depends on x and y respectively so when x =1 (is high) then a should be print and when y=1(is high) then b should be print. so how we will print and where we will print can you please give me suggestions.
If you are referring specifically to uvm_object::print(), we recommend overriding do_print() or even using convert2string() and formatting your output exactly the way you want it. UVM’s built-in printer facility can give you quick output, but eventually you’ll need to learn how do do it yourself anyway. See
@dave_59 I referred the uvm_object ::print method and I coded also but I didn’t get the output can you please help me?
`include "uvm_macros.svh"
import uvm_pkg::*;
class transaction extends uvm_object;
rand int a;
rand int b;
bit x;
bit y;
`uvm_object_utils_begin(transaction)
`uvm_field_int(a, UVM_DEFAULT)
`uvm_field_int(b, UVM_DEFAULT)
`uvm_object_utils_end
virtual function void do_print(uvm_printer printer);
super.do_print(printer);
if(x==1) begin
printer.print_field("a",this.a,32,UVM_DEC);
if(y==1) begin
printer.print_field("b",this.b,32,UVM_DEC);
function new(string name = "transaction");
super.new(name);
class base_test extends uvm_test;
`uvm_component_utils(base_test)
function new(string name = "base_test", uvm_component parent=null);
super.new(name, parent);
transaction trans = transaction::type_id::create("trans");
trans.randomize();
trans.print();
`uvm_info(get_type_name(), $sformatf("Contents: \n%s", trans.sprint()), UVM_LOW)
module tb;
initial run_test("base_test");
OUTPUT:-
UVM_INFO @ 0: reporter [RNTST] Running test base_test...
Name Type Size Value
trans transaction - @349
a integral 32 'h1f135537
b integral 32 'he6195fe3
UVM_INFO testbench.sv(102) @ 0: uvm_test_top [base_test] Contents:
do_print append to the output of the field automation macros. If you are going to use print/sprint and the field automation macros and add the do_print(), then you need to do one of
- remove the
uvm_field_macros, recommended - use
convert2stringinstead of print/sprint. - change the UVM_DEFAULT to UVM_NOPRINT
@dave_59 Thanks for contributing, I got the output.
`include “uvm_macros.svh”
import uvm_pkg::*;
rand int a;
rand int b;
bit x=1;
bit y=0;
uvm_object_utils_begin(transaction) uvm_field_int(a, UVM_NOPRINT)
uvm_field_int(b, UVM_NOPRINT) uvm_object_utils_end
if(x==1) begin
printer.print_field(“a”,this.a,32,UVM_DEC);
if(y==1) begin
printer.print_field(“b”,this.b,32,UVM_DEC);
function new(string name = “transaction”);
super.new(name);
function new(string name = “base_test”, uvm_component parent=null);
transaction trans = transaction::type_id::create(“trans”);
trans.randomize();
trans.print();
`uvm_info(get_type_name(), $sformatf(“Contents: \n%s”, trans.sprint()), UVM_LOW)
module tb;
initial run_test(“base_test”);
Output:-
UVM_INFO @ 0: reporter [RNTST] Running test base_test…
**Name Type Size Value **
trans transaction - @349 **
** a integral 32 'd521360695
**UVM_INFO testbench.sv(43) @ 0: uvm_test_top [base_test] Contents: **
