Hi All,
Could any one please explain where are the uvm_top and uvm_test_top in uvm tb hierarchy?
Rahul Kumar
Hi All,
Rahul Kumar
Hi Rahul,
Please check the below link.
diff between uvm_top and uvm_test_top
-Abhijeet
In reply to abhijeet Sahoo:
Hi Abhijeet,
Thanks for reply,
I could not understand(hierarchy) the difference b/w uvm_top and uvm_test_top, If i want to access a variable from test to inside TB_top using hierarchical path, what would be the hierarchy please have a look at below code?
module tb_top;
#10ns;
uvm_top.uvm_test_top.count=10; <- getting error
class base_test extends uvm_test;
int count;
Rahul
