I’m facing a issue with the simple test class (code below) and the error is
** Error: env_test.sv(1): near “uvm_test”: syntax error, unexpected IDENTIFIER
** Error: env_test.sv(1): Error in class extension specification.
Code:
class env_test extends uvm_test;
`uvm_component_utils(env_test)
//----- Handler -----
adder_env adder_env_h;
//----- Constructor -----
super.new(name, parent);
endfunction: new
//----- Beuild Phase Creating and Assigning the Handler -----
adder_env_h = adder_env::typ_id::create(“adder_env_h”, this);
endfunction: build_phase
endclass: env_test
The command used to execute is “make LIBNAME=uvm_dpi64 BITS=64 -f Makefile.questa comp”
Can you suggest me where im going wrong?
Thanks.
