I need to pass the value via inline constraint using same variable name. Like below.
Code:**
enum dev_t{TEST,TEST1};
class parent_seq extends uvm_sequence;
rand dev_t dev_t;
soft constraint {dev_t == TEST1;}
class seq extends parent_seq;
body()
$display(“%s”,dev_t.name()); ==> TEST1
class Seq1 extends parent_seq;
Body()
dev_t = “TEST”
`uvm_do_with(seq, {seq.dev_t == dev_t; } )
endbody;
endclass:seq1
for above piece of code i am not getting proper value. we are expecting DEV_t should be TEST. But class seq print returning TEST1[soft constraint value not generated based on in line constraint value].
please correct me if any of above code is wrong…
selvavinayakam.na
