I have look around the forums, and understood how to use the bind feature (Which works great).
So I have an interface that i made bind to some module in the RTL,
currently this is using as a White-Box monitor.
Is there way to “write” this interface/bind into factory, so other components in UVM env
will also be able to get/work on same i/f?
As i said currently its only for White Box monitor,
but if i will want to add checkers etc, i need to have access enc/cfg/sequencer object etc…
So i think register the i/f into the factory will be best solution.
If you didn’t search the forum(s) for this topic, then I recommend doing so, there are many postings on this. Try searching on “bind interface internal” or something like that. Below are links I found in a couple of minutes that discuss binding to the DUT.
