Here is the example. You can directly run it successfully.
import uvm_pkg::*;
`include "uvm_macros.svh"
`timescale 1ns/10ps
* interface
interface dut_if;
logic clock, reset, put, get, full_bar, empty_bar;
logic [15:0] data_in;
logic [15:0] data_out;
endinterface : dut_if
* DUT
module FIFO (
clk,
reset,
put,
get,
data_in,
empty_bar,
full_bar,
data_out
parameter DEPTH = 8;
parameter WIDTH = 16;
parameter POINTER_WIDTH = 3;
input clk;
input reset;
input put;
input get;
input [WIDTH-1:0] data_in;
output empty_bar;
output full_bar;
output [WIDTH-1:0] data_out;
reg [POINTER_WIDTH:0] wr_ptr;
reg [POINTER_WIDTH:0] rd_ptr;
reg empty_bar;
reg full_bar;
reg [WIDTH-1:0] data_out;
reg [WIDTH-1:0] FIFO_3 [DEPTH-1:0];
wire [POINTER_WIDTH-1:0] wr_ptr_int;
wire [POINTER_WIDTH-1:0] rd_ptr_int;
wire full;
wire empty;
wire [POINTER_WIDTH:0] wr_rd;
wire put_e;
wire get_e;
assign wr_rd = wr_ptr - rd_ptr;
assign full = (wr_rd == 4'b1000);
assign empty = (wr_rd == 4'b0000);
assign put_e = (put && full == 1'b0);
assign get_e = (get && empty == 1'b0);
assign wr_ptr_int = wr_ptr[POINTER_WIDTH-1:0];
assign rd_ptr_int = rd_ptr[POINTER_WIDTH-1:0];
always @(posedge clk)
if (reset)
wr_ptr <= 3'b000;
rd_ptr <= 3'b000;
end else
if (put_e)
FIFO_3 [wr_ptr_int] <= data_in;
wr_ptr <= wr_ptr + 3'b001;
if (get_e)
rd_ptr <= rd_ptr + 3'b001;
always @(rd_ptr_int)
data_out <= FIFO_3 [rd_ptr_int-3'b001];
always @(empty or full)
empty_bar <= ~empty;
full_bar <= ~full;
endmodule : FIFO
* top
dut_if inf();
FIFO dut (
.clk(inf.clock),
.reset(inf.reset),
.put(inf.put),
.get(inf.get),
.full_bar(inf.full_bar),
.empty_bar(inf.empty_bar),
.data_in(inf.data_in),
.data_out(inf.data_out)
initial
uvm_config_db #(virtual dut_if)::set(null, "uvm_test_top.env_h.agent_1_h.data_driver_h", "dut_if", inf);
uvm_config_db #(virtual dut_if)::set(null, "uvm_test_top.env_h.agent_2_h.rst_driver_h", "dut_if", inf);
uvm_config_db #(virtual dut_if)::set(null, "uvm_test_top.env_h.agent_1_h.monitor_1_h", "dut_if", inf);
uvm_config_db #(virtual dut_if)::set(null, "uvm_test_top.env_h.agent_3_h.monitor_2_h", "dut_if", inf);
run_test("test_1");
always
#5 inf.clock = !inf.clock;
initial
inf.clock = 1'b1;
inf.reset = 1'b1;
repeat (3) @(posedge inf.clock);
#5
inf.reset = 1'b0;
endmodule : top
* transaction
class data_transaction extends uvm_sequence_item;
rand logic [15 : 0] data_in;
rand logic put;
rand logic get;
function new(string name = "data_transaction");
super.new(name);
`uvm_object_utils_begin(data_transaction)
`uvm_field_int(data_in, UVM_ALL_ON)
`uvm_field_int(put, UVM_ALL_ON)
`uvm_field_int(get, UVM_ALL_ON)
`uvm_object_utils_end
class rst_transaction extends uvm_sequence_item;
logic rst;
function new(string name = "rst_transaction");
super.new(name);
`uvm_object_utils_begin(rst_transaction)
`uvm_field_int(rst, UVM_ALL_ON)
* sequence
// FIFO test 1
// write FIFO from empty to full -> read FIFO from full to empty
class FIFO_test_1_sequence extends uvm_sequence #(data_transaction);
`uvm_object_utils(FIFO_test_1_sequence)
data_transaction tr;
function new(string name = "data_seq_1");
super.new(name);
task body();
for (int i = 0; i < 40; i++) begin
tr = data_transaction::type_id::create("tx_data_tr");
start_item(tr);
if (i < 20) begin
if (!tr.randomize() with {tr.put == 1'b1; tr.get == 1'b0;}) begin
`uvm_error("Sequence", "Randomization failure for trasaction")
else begin
if (!tr.randomize() with {tr.put == 1'b0; tr.get == 1'b1;}) begin
finish_item(tr);
endclass : FIFO_test_1_sequence
// Write FIFO from empty to half-full, and then read/write at the same time
class FIFO_test_2_sequence extends uvm_sequence #(data_transaction);
`uvm_object_utils(FIFO_test_2_sequence)
super.new(name);
task body();
tr = data_transaction::type_id::create("rd_tr");
start_item(tr);
if (i < 4) begin
else begin
if (!tr.randomize() with {tr.put == 1'b1; tr.get == 1'b1;}) begin
finish_item(tr);
class FIFO_rst_sequence extends uvm_sequence #(rst_transaction);
`uvm_object_utils(FIFO_rst_sequence)
rst_transaction tr;
function new(string name = "rst_seq");
super.new(name);
task body();
tr = rst_transaction::type_id::create("rst_tx_tr");
start_item(tr);
tr.rst = 1'b1;
finish_item(tr);
start_item(tr);
tr.rst = 1'b0;
finish_item(tr);
* sequencer
class rst_sequencer extends uvm_sequencer #(rst_transaction);
`uvm_component_utils(rst_sequencer)
super.new(name, parent);
endclass : rst_sequencer
class data_sequencer extends uvm_sequencer #(data_transaction);
`uvm_component_utils(data_sequencer)
endclass : data_sequencer
* virtual sequence
class top_vseq_base extends uvm_sequence #(uvm_sequence_item);
`uvm_object_utils(top_vseq_base)
rst_sequencer rst_sqr_h;
data_sequencer data_sqr_h;
function new(string name = "top_vseq_base");
super.new(name);
class vseq_rst_data extends top_vseq_base;
`uvm_object_utils(vseq_rst_data)
FIFO_test_1_sequence fifo_data_seq_h;
FIFO_rst_sequence fifo_rst_seq_h;
function new(string name = "vseq_rst_data");
super.new(name);
task body();
fifo_data_seq_h = FIFO_test_1_sequence::type_id::create("fifo_data_seq_h");
fifo_rst_seq_h = FIFO_rst_sequence::type_id::create("fifo_rst_seq_h");
fifo_rst_seq_h.start(rst_sqr_h);
fifo_data_seq_h.start(data_sqr_h);
join
endclass : vseq_rst_data
* driver
class data_driver extends uvm_driver #(data_transaction);
`uvm_component_utils(data_driver)
virtual dut_if driver2dut;
super.build_phase(phase);
if (!uvm_config_db #(virtual dut_if)::get(this, "", "dut_if", driver2dut))
`uvm_info("DATA_DRIVER", "uvm_config_db::get failed!", UVM_HIGH)
task reset_check();
forever begin
@(posedge driver2dut.clock);
if (driver2dut.reset) begin
driver2dut.put = 1'b0;
driver2dut.get = 1'b0;
task send_data();
forever begin
if (!driver2dut.reset) begin
seq_item_port.get_next_item(tr);
#1
driver2dut.put = tr.put;
driver2dut.get = tr.get;
driver2dut.data_in = tr.data_in;
seq_item_port.item_done();
reset_check();
send_data();
join
endclass : data_driver
class rst_driver extends uvm_driver #(rst_transaction);
`uvm_component_utils(rst_driver)
rst_transaction tr;
`uvm_info("RST_DRIVER", "uvm_config_db::get failed!", UVM_HIGH)
driver2dut.reset = tr.rst;
repeat (3) @(negedge driver2dut.clock);
endclass : rst_driver
* monitor
class my_monitor_1 extends uvm_monitor;
`uvm_component_utils(my_monitor_1)
virtual dut_if dut2monitor1;
uvm_analysis_port #(data_transaction) ap;
ap = new("monitor_1_ap", this);
if (!uvm_config_db #(virtual dut_if)::get(this, "", "dut_if", dut2monitor1))
$display("monitor_1 uvm_config_db::get failed");
forever
@(posedge dut2monitor1.clock)
tr = data_transaction::type_id::create("tr");
if (!dut2monitor1.reset & dut2monitor1.full_bar & dut2monitor1.put)
tr.data_in = dut2monitor1.data_in;
ap.write(tr);
endclass : my_monitor_1
class my_monitor_2 extends uvm_monitor;
`uvm_component_utils(my_monitor_2)
virtual dut_if dut2monitor2;
ap = new("monitor_2_ap", this);
if (!uvm_config_db #(virtual dut_if)::get(this, "", "dut_if", dut2monitor2))
$display("monitor_2 uvm_config_db::get failed");
forever
@(posedge dut2monitor2.clock)
if (!dut2monitor2.reset & dut2monitor2.empty_bar & dut2monitor2.get)
#1
tr.data_in = dut2monitor2.data_out;
ap.write(tr);
endclass : my_monitor_2
* agent
class my_agent_1 extends uvm_component;
`uvm_component_utils(my_agent_1)
data_driver data_driver_h;
data_sequencer data_sequencer_h;
my_monitor_1 monitor_1_h;
data_driver_h = data_driver::type_id::create("data_driver_h", this);
data_sequencer_h = data_sequencer::type_id::create("data_sequencer_h", this);
monitor_1_h = my_monitor_1::type_id::create("monitor_1_h", this);
super.connect_phase(phase);
data_driver_h.seq_item_port.connect(data_sequencer_h.seq_item_export);
ap = monitor_1_h.ap;
endclass : my_agent_1
class my_agent_2 extends uvm_component;
`uvm_component_utils(my_agent_2)
rst_driver rst_driver_h;
rst_sequencer rst_sequencer_h;
rst_driver_h = rst_driver::type_id::create("rst_driver_h", this);
rst_sequencer_h = rst_sequencer::type_id::create("rst_sequencer_h", this);
rst_driver_h.seq_item_port.connect(rst_sequencer_h.seq_item_export);
endclass : my_agent_2
class my_agent_3 extends uvm_component;
`uvm_component_utils(my_agent_3)
my_monitor_2 monitor_2_h;
monitor_2_h = my_monitor_2::type_id::create("monitor_2_h", this);
ap = monitor_2_h.ap;
endclass : my_agent_3
* scoreboard
class my_scoreboard extends uvm_scoreboard;
`uvm_component_utils(my_scoreboard);
uvm_blocking_get_port #(data_transaction) exp_port;
uvm_blocking_get_port #(data_transaction) act_port;
data_transaction tr_act, tr_exp;
bit result;
exp_port = new("exp_port", this);
act_port = new("act_port", this);
forever
exp_port.get(tr_exp);
act_port.get(tr_act);
result = tr_exp.compare(tr_act);
if (result)
$display("Compare SUCCESSFULLY");
`uvm_warning("WARNING", "Compare FAILED")
$display("The expected data is");
tr_exp.print();
$display("The actual data is");
tr_act.print();
endclass : my_scoreboard
* environment
class my_environment extends uvm_env;
`uvm_component_utils(my_environment);
my_agent_1 agent_1_h;
my_agent_2 agent_2_h;
my_agent_3 agent_3_h;
my_scoreboard scoreboard_h;
uvm_tlm_analysis_fifo #(data_transaction) agt_1_scb_fifo;
uvm_tlm_analysis_fifo #(data_transaction) agt_2_scb_fifo;
agent_1_h = my_agent_1::type_id::create("agent_1_h", this);
agent_2_h = my_agent_2::type_id::create("agent_2_h", this);
agent_3_h = my_agent_3::type_id::create("agent_3_h", this);
scoreboard_h = my_scoreboard::type_id::create("scoreboard_h", this);
agt_1_scb_fifo = new("agt_1_scb_fifo", this);
agt_2_scb_fifo = new("agt_2_scb_fifo", this);
agent_1_h.ap.connect(agt_1_scb_fifo.analysis_export);
agent_3_h.ap.connect(agt_2_scb_fifo.analysis_export);
scoreboard_h.exp_port.connect(agt_1_scb_fifo.blocking_get_export);
scoreboard_h.act_port.connect(agt_2_scb_fifo.blocking_get_export);
endclass : my_environment
* test
// vsim top +UVM_TESTNAME=test_1
// vsim top +UVM_TESTNAME=test_2
// select different test cases
class top_test_base extends uvm_test;
`uvm_component_utils(top_test_base)
my_environment env_h;
function new(string name = "top_test_base", uvm_component parent);
env_h = my_environment::type_id::create("env_h", this);
task init_vseq(top_vseq_base vseq);
vseq.data_sqr_h = env_h.agent_1_h.data_sequencer_h;
vseq.rst_sqr_h = env_h.agent_2_h.rst_sequencer_h;
endclass : top_test_base
class test_1 extends top_test_base;
`uvm_component_utils(test_1)
vseq_rst_data vseq_h;
function new(string name = "test_1", uvm_component parent);
vseq_h = vseq_rst_data::type_id::create("vseq_h");
phase.raise_objection(this);
init_vseq(vseq_h);
vseq_h.start(null);
phase.drop_objection(this);
endclass : test_1
Now if I move the uvm_agent class in front of uvm_driver class. Like this
import uvm_pkg::*;
`timescale 1ns/10ps
* interface
interface dut_if;
* DUT
module FIFO (
clk,
reset,
put,
get,
data_in,
empty_bar,
full_bar,
data_out
input clk;
input reset;
input put;
input get;
output empty_bar;
output full_bar;
reg empty_bar;
reg full_bar;
wire full;
wire empty;
wire put_e;
wire get_e;
if (reset)
wr_ptr <= 3'b000;
rd_ptr <= 3'b000;
end else
if (put_e)
if (get_e)
full_bar <= ~full;
endmodule : FIFO
* top
dut_if inf();
FIFO dut (
.clk(inf.clock),
.reset(inf.reset),
.put(inf.put),
.get(inf.get),
initial
run_test("test_1");
always
initial
inf.clock = 1'b1;
inf.reset = 1'b1;
#5
inf.reset = 1'b0;
endmodule : top
* transaction
rand logic put;
rand logic get;
super.new(name);
logic rst;
super.new(name);
* sequence
// FIFO test 1
super.new(name);
task body();
start_item(tr);
if (i < 20) begin
else begin
finish_item(tr);
super.new(name);
task body();
start_item(tr);
if (i < 4) begin
else begin
finish_item(tr);
rst_transaction tr;
super.new(name);
task body();
start_item(tr);
tr.rst = 1'b1;
finish_item(tr);
start_item(tr);
tr.rst = 1'b0;
finish_item(tr);
* sequencer
* virtual sequence
super.new(name);
super.new(name);
task body();
join
* agent
* driver
task reset_check();
forever begin
task send_data();
forever begin
#1
reset_check();
send_data();
join
rst_transaction tr;
* monitor
forever
ap.write(tr);
forever
#1
ap.write(tr);
* scoreboard
bit result;
forever
if (result)
tr_exp.print();
tr_act.print();
* environment
* test
init_vseq(vseq_h);
vseq_h.start(null);
endclass : test_1
It will cause error.
The error is “token “data_driver” should be a valid type”.
For more information, below is the command
vcs -dubug_access+all -kdb -lca -sverilog uvm_dpi.cc -CFLAGS -DVCS -f filelist.f
simv +UVM_TR_RECORD
From what I know the order doesn’t matter because the uvm_phase will schedule the process automatically. How is this happening? Is there anything I missed or that’s just how it is?
