hi:
I define a class:
clase mac_seq #(type T=mac_base_seq) extends mac_base_seq ;
`uvm_object_param_utils(T)
task body();
T Txq;
Txq = T::type_id::create(“txq”);
Txq.start(p_sequencer);
I Want to config the class type of Txq by the commandlinf of +uvm_set_inst_override=“mac_base_seq,mac_seq(#mac_base_seq_ext),test_seq_m”;
mac_base_seq is base class of mac_base_seq_ext.
But reprot Cannot register override for original type … in uvm_factory.
how to meet the requirement in the uvm?
In reply to birdluo:
The +uvm_set_inst_override switch only works with classes that have a string name associated with with the factory. The `uvm_object_param_utils macro does not register a class with a string name, it only does type based factory registration.
To make +uvm_set_inst_override work, you can do one of two things. Extend an un-parameterized class around your parameterized class and use that as your override:
class mac_seq_mac_base_seq_ext extends mac_seq(#mac_base_seq_ext);
`uvm_object_utils(mac_seq_mac_base_seq_ext)
Don’t use `uvm_object_param_utils to register your class with the factory. See http://go.mentor.com/mcem
the issue has be fixed after Extend an un-parameterized class;
