UVM SEQUENCE USAGE
HI All,
Please suggest;
class ethernet_main_seq extends main_seq;
busy_seq busy_seq_h;
feature_seq feature_seq_h;
uvm_do_with(busy_seq_h.mode==1); uvm_do_with(feature_seq_h.addr==1);
class busy_seq extends main_seq;
feature_seq feature_seq_h; //GIVING ERROR
class feature_seq extends main_seq;
I would like to use feature_seq inside busy_seq, but I am not able to use it.
Thank You,
In reply to Mahesh K:
You need to explain what “GIVING ERROR” means. Is it a compilation error? Run time error? Do you need to change the ordering of how your files are compiled to ensure that the class is defined prior to referencing it?
