UVM sequence scoreboard problem. in what order does the run_phase get executed?
Clarify the problem:
in my test, it is just
task run_phase();
A.start();
B is a scoreboard, and in the run phase it frees the token.
In B run_phase:
super.run_phase();
Forever begin
if()
freeToken();
A is a sequence , and here what going on is:
task body();
while() begin
if(getToken())
break;
there is a interlock going on between A and B. in A, there is a loop which wait for B to free a token. However it seems A just wait forever and B never get executed if I code them like this. Am I understanding something wrong? It might be the loop part going wrong but when I remove the loop thing, it seems fine.
Any ideas?
In reply to Guozhu He:
Can you post the body methods of your 2 sequences?
In reply to bmorris:
Oh. My previous statement is wrong. Actually B is a scoreboard.
In B run_phase:
super.run_phase();
Forever begin
if()
freeToken();
task body();
while() begin
if(getToken())
break;
while() begin
 if(getToken())
 break;
Does getToken() have any blocking statements in it? Otherwise, this may lock up your simulator.
Forever begin
 if()
 freeToken();
Why do you have a blank if() statement? I’m having trouble understanding the intent of your code. Could you post the freeToken and getToken methods?
run_phase of all the components created run in parallel like in a fork join statement.
But there is no run_phase in sequences (there is whole set of different way of communication btw sequences/sequences and driver that need to be looked on)and hence your code is not working in way you want it do.
Hope this helps.
