In reply to Boogeyman:
- Calling start() for a sequence doesn’t randomize the sequence. It only starts the existing sequence in its current state.
- Calling randomize() with {} will randomize the sequence per the specified constraints. Calling start() afterwards doesn’t change any values.
- Don’t use p_sequencer. All virtual sequences should have the required sequencer handles assigned prior to starting and run on a ‘null’ sequencer.
