Dear all
I want to run configurable object including sequence item definition.
I need to access from sequence a parameter defined in the uvm component thanks to the UVM hierarchy. As my configurable object may be instanciated several times, I cannot use uvm data base mechanism as the access is defined by a string name (will be the same for each component instance).
Is there any other mechanism to access parameter from UVM_COMPONENT to UVM_SEQUENCE ?
The background of the mechanism is to define for an UVM agent, a sequence item transaction from a configuration text file declared with the configuration of the agent (structural part of UVM). I may be not recommanded by the cockbook, that It will allow to have a complete generic agent that can be configurated by text file for defining the sequence item transaction, and be only configurated.
Thanks for you help.
regards
Louis
