Hi Everyone, I am having a doubt regarding the scoreboard and simulated waveform. Like for example, in UART like for the parity error case I am getting proper waveform based on interrupt but while scoreboard results are showing no parity error. What might be an issue? Pasting the uart scoreboard code,uart sequence code and Waveform and Simulation results here:
UART SEQUENCE → PARITY ERROR
//---------------------------------------------------------PARITY ERROR---------------------------------------//
class seq5 extends base_seq;
`uvm_object_utils(seq5)
function new(string name="seq5");
super.new(name);
virtual task body();
req=uart_xtn::type_id::create("req");
/*if(!uvm_config_db#(reg_config)::get(get_sequencer(), "","reg_config",r_cfg))
`uvm_fatal("R_CFG","Failed to get()")*/
//------------------------------------------LCR-->DLR REG ACCESS---------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b1000_0000;wb_we_i==1'b1;wb_addr_i==3;})
finish_item(req);
//-------------------------------------------DLR_MSB--------------------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_0000;wb_we_i==1'b1;wb_addr_i==1;})
finish_item(req);
//-------------------------------------------DLR_LSB-------------------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0011_0110;wb_we_i==1'b1;wb_addr_i==0;})
finish_item(req);
//-------------------------------------------LCR-->NORMAL REG ACCESS---------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0001_1011;wb_we_i==1'b1;wb_addr_i==3;})
finish_item(req);
//--------------------------------------------FCR---------------------------------//
/*start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_0110;wb_we_i==1'b1;wb_addr_i==2;})
finish_item(req);*/
start_item(req);
finish_item(req);
//--------------------------------------------IER----------------------------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_0100;wb_we_i==1'b1;wb_addr_i==1;})
finish_item(req);
//--------------------------------------------THR---------------------------------//
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_0111;wb_we_i==1'b1;wb_addr_i==0;})
finish_item(req);
//--------------------------------------------IIR---------------------------------//
start_item(req);
assert(req.randomize()with{wb_addr_i==2;wb_we_i==0;})
finish_item(req);
get_response(req);
if(req.wb_dat_o==8'b1100_0110)
start_item(req);
assert(req.randomize()with{wb_we_i==0;wb_addr_i==5;})
finish_item(req);
if(req.wb_dat_o==8'b1100_0100)
start_item(req);
assert(req.randomize()with{wb_we_i==0;wb_addr_i==0;})
finish_item(req);
if(req.wb_dat_o==8'b1100_1100)
start_item(req);
finish_item(req);
if(req.wb_dat_o==8'b1100_0010)
start_item(req);
assert(req.randomize()with{wb_we_i==1;wb_addr_i==0;wb_dat_i==8'b0000_0101;})
finish_item(req);
//-----------------------------------------------PARITY ERROR-----------------------------//
class seq6 extends base_seq;
`uvm_object_utils(seq6)
function new(string name="seq6");
super.new(name);
start_item(req);
finish_item(req);
start_item(req);
finish_item(req);
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0001_1011;wb_we_i==1'b1;wb_addr_i==0;})
finish_item(req);
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_1011;wb_we_i==1'b1;wb_addr_i==3;})
finish_item(req);
start_item(req);
finish_item(req);
start_item(req);
finish_item(req);
start_item(req);
assert(req.randomize()with{wb_dat_i==8'b0000_1111;wb_we_i==1'b1;wb_addr_i==0;})
finish_item(req);
start_item(req);
finish_item(req);
get_response(req);
start_item(req);
finish_item(req);
start_item(req);
finish_item(req);
start_item(req);
finish_item(req);
start_item(req);
finish_item(req);
UART SCOREBOARD
class uart_scoreboard extends uvm_scoreboard;
`uvm_component_utils(uart_scoreboard)
uvm_tlm_analysis_fifo #(uart_xtn) fifo_h[];
uart_env_config env_cfg;
uart_xtn xtn1,xtn2;
uart_xtn cov_data;
int thr1size,thr2size,rb1size,rb2size;
extern function new(string name="uart_scoreboard",uvm_component parent);
extern function void build_phase(uvm_phase phase);
extern task run_phase(uvm_phase phase);
extern function void check_phase(uvm_phase phase);
/*covergroup uart_signals_cov;
option.per_instance=1;
DATA:coverpoint cov_data.wb_dat_i[7:0] {bins wb_dat_i={[0:255]};}
ADDRESS:coverpoint cov_data.wb_addr_i[2:0] {bins wb_addr_i={[0:7]};}
ENABLE:coverpoint cov_data.wb_we_i {bins read={0};
bins writee={1};}
endgroup*/
covergroup uart_lcr_cov;
CHAR_SIZE:coverpoint cov_data.lcr[1:0] {bins five={2'b00};
bins six={2'b01};
bins seven={2'b10};
bins eight={2'b11};}
STOP_BIT:coverpoint cov_data.lcr[2] {bins one={1'b0};
bins two={1'b1};}
PARITY_ENB:coverpoint cov_data.lcr[3] {bins on={1'b1};
bins off={1'b0};}
EVEN_PARITY:coverpoint cov_data.lcr[4] {bins even={1'b1};
bins odd={1'b0};}
STICKY_PARITY:coverpoint cov_data.lcr[5] {bins on={1'b1};
bins off={1'b0};}
BREAK_CONTROL:coverpoint cov_data.lcr[6] {bins on={1'b1};
bins off={1'b0};}
DIVISOR_LATCH:coverpoint cov_data.lcr[7] {bins on={1'b1};
bins off={1'b0};}
//CHAR_SIZE_X_STOP_BIT_X_EV_ODD_PARITY: cross CHAR_SIZE,STOP_BIT,EVEN_PARITY;
endgroup
covergroup uart_ier_cov;
RCVD_INT: coverpoint cov_data.ier[0] { bins dis = {1'b0};
bins en = {1'b1}; }
THRE_INT: coverpoint cov_data.ier[1] { bins dis = {1'b0};
bins en = {1'b1}; }
LSR_INT: coverpoint cov_data.ier[2] { bins dis = {1'b0};
bins en = {1'b1}; }
endgroup
covergroup uart_fcr_cov;
RFIFO: coverpoint cov_data.fcr[1] { bins dis = {1'b0};
bins clr = {1'b1}; }
TFIFO: coverpoint cov_data.fcr[2] { bins dis = {1'b0};
TRG_LVL: coverpoint cov_data.fcr[7:6] { bins one = {2'b00};
bins four = {2'b01};
bins eight = {2'b10};
bins fourteen = {2'b11}; }
endgroup
covergroup uart_iir_cov;
IIR: coverpoint cov_data.iir[3:1] {bins lsr = {3'b011};
bins rdf = {3'b010};
bins ti_o = {3'b110};
bins threm = {3'b001}; }
endgroup
covergroup uart_lsr_cov;
DATA_READY: coverpoint cov_data.lsr[0] {bins fifoempty = {1'b0};
bins datarcvd = {1'b1}; }
OVER_RUN: coverpoint cov_data.lsr[1] {bins nooverrun = {1'b0};
bins overrun = {1'b1}; }
PARITY_ERR: coverpoint cov_data.lsr[2] {bins noparityerr = {1'b0};
bins parityerr = {1'b1} ;}
FRAME_ERR: coverpoint cov_data.lsr[3] {bins noframeerr = {1'b0};
bins frameerr = {1'b1}; }
BREAK_INT: coverpoint cov_data.lsr[4] {bins nobreakint = {1'b0};
bins breakint = {1'b1}; }
THR_EMP: coverpoint cov_data.lsr[5] {bins thrnotemp = {1'b0};
bins thremo = {1'b1}; }
endgroup
function uart_scoreboard::new(string name="uart_scoreboard",uvm_component parent);
super.new(name,parent);
//uart_signals_cov=new();
uart_fcr_cov=new();
uart_iir_cov=new();
uart_ier_cov=new();
uart_lsr_cov=new();
uart_lcr_cov=new();
function void uart_scoreboard::build_phase(uvm_phase phase);
if(!uvm_config_db#(uart_env_config)::get(this,"","uart_env_config",env_cfg))
`uvm_fatal("ENV_CONFIG","Cannot get the env_cfg from config_db. Have you set() iy?")
if(env_cfg.has_wb_agent)
fifo_h=new[env_cfg.no_of_agts];
foreach(fifo_h[i])
fifo_h[i]=new($sformatf("fifo_h[%0d]",i),this);
super.build_phase(phase);
task uart_scoreboard::run_phase(uvm_phase phase);
forever
fifo_h[0].get(xtn1);
cov_data=xtn1;
// uart_signals_cov.sample();
uart_lcr_cov.sample();
uart_ier_cov.sample();
uart_fcr_cov.sample();
uart_iir_cov.sample();
uart_lsr_cov.sample();
forever
fifo_h[1].get(xtn2);
cov_data=xtn2;
//uart_signals_cov.sample();
join
function void uart_scoreboard::check_phase(uvm_phase phase);
$display("THE VALUES SENT BY UART1: %p\n",xtn1.thr);
$display("THE VALUES SENT BY UART2: %p\n",xtn2.thr);
$display("THE VALUES RECEIVED BY UART1: %p\n",xtn1.rb);
$display("THE VALUES RECEIVED BY UART2 : %p\n",xtn2.rb);
//FULL DUPLEX CONDITION AND HALF DUPLEX CONDITION
thr1size=xtn1.thr.size();
thr2size=xtn2.thr.size();
rb1size=xtn1.rb.size();
rb2size=xtn2.rb.size();
if((thr1size!=0 && thr2size==0) || (thr1size==0 && thr2size!=0))
if((xtn1.thr==xtn2.rb) || (xtn2.thr == xtn1.rb))
$display("Half Duplex is Successful");
if((xtn1.thr==xtn2.rb) && (xtn2.thr==xtn1.rb))
$display("Full Duplex is Successful");
//PARITY ERROR CONDITION
$display("LCR:%0b",xtn2.lcr);
$display("IER:%0b",xtn2.ier);
$display("IIR:%0b",xtn2.iir);
$display("LSR:%0b",xtn2.lsr);
if(xtn2.lcr[3]==1 && xtn2.ier[2]==1 && xtn2.iir[3:1]==3 && xtn2.lsr[2]==1)
$display("PARITY ERROR");
$display("NO PARITY ERROR");
Simualted Results
Waveform for Parity Error
In Waveform my LSR value is a5 but in simulated waveform lsr value is zero. Why i am getting this difference??
