I need to pass a clk_period value via from a test to clk_period check assertion in top module via uvm_resource_db.
Please let me know what is wrong in this code
test :
class test_x_basic extends base_x_test;
realtime time_period;
`uvm_component_utils(test_x_basic)
function new (string name ="test_x_basic", uvm_component parent =null);
super.new(name,parent);
uvm_resource_db #(realtime)::set("CLK_PERIOD", "time_period", 6);
set_type_override_by_type(soc_virtual_seq::get_type(),test_x_basic_seq::get_type());
set_type_override_by_type(soc_config::get_type(),test_x_basic_config::get_type());
super.build_phase(phase);
top module
module tb_top ();
realtime clk_period;
initial
#0;
uvm_resource_db #(realtime)::read_by_name("CLK_PERIOD","time_period", soc_tb_top.clk_period);
//if(!uvm_resource_db #(realtime)::read_by_name("CLK_PERIOD","time_period", clk_period,this))
// `uvm_fatal("read_y_name failed for resource in this scope");
run_test();
`ifdef ASSERT_CHECK_EN
`include "list_of_clk_assertion.sv"
`endif
list_of_assertion.sv
bind top.xyz clk_freq_check pclk_check (pclk,rstn, tb_top.clk_period,0,0,0,500,"pclk");
clk_period above is not picking the value given from test
