I see a difference in the way the simulation log messages are printed when OVM test bench code was converted to UVM.
In the new UVM test bench, when simulation was run with verbosity set to UVM_NONE, the test case passed. But the same test case fails when the simulation was run with verbosity set to UVM_DEBUG.
When simulation was run with verbosity of UVM_DEBUG, test case is failing with UVM_ERROR type messages printed in the log file. Though the severity for the uvm_report_error method was UVM_MEDIUM, the message was not printed when the simulation was run with UVM_VERBOSITY set to UVM_NONE.
+UVM_VERBOSITY command line argument value is used to set the threshold value for UVM messages reporting. All the messages (uvm_report_info/warning etc) which has a verbosity value greater than the threshold are ignored. Only the messages which has a verbosity lesser than the threshold value are printed.
i.e., if you run with +UVM_VERBOSITY=UVM_NONE, then only UVM_NONE messages shall be printed.
If you run with +UVM_VERBOSITY=UVM_LOW, then only the UVM_NONE, UVM_LOW messages shall be printed and so on..
In your case, reporting severity is set to UVM_MEDIUM (200) where as the threshold (+UVM_VERBOSITY) is set to UVM_NONE (0) and hence the message is not printed.
As I understand from the first post, seems like “San” is using uvm_report_error method.
I just explained that the behavior reported is indeed expected one.
For uvm_report_error method, error will not be reported if +UVM_VERBOSITY is set to UVM_NONE, as the default verbosity for uvm_report_error is UVM_LOW.
And yes the reported issue wouldn’t have occurred, had the macro `uvm_error been used; because the macros enforce a verbosity setting of UVM_NONE for warning/error/fatal so that they won’t be mistakenly switched off.
May be, I should have added a recommendation to use `uvm_error() along with the explanation.
there was typo in my previous mail ,i am referring to uvm only.
Currently i am working on ovm (not moved to uvm yet)
As far as i remember it was issue in earlier releases of OVM.
Where as user wrote like this "ovm_report_error(“XYZ”,“INTO THE WILD”,OVM_MEDIUM) " if you run with verbosity OVM_NONE then it will not be printed where as if you run with OVM_DEBUG it will be printed (as you explained)
But ERROR is ERROR ,based on that only we will concluded whether test passed it or not.But the above one filters it out based on verbosity which is wrong.
so later versions of OVM have corrected that (if you look the source code)
when ever some one call ovm_report(error|fatal) they gonna ignore the severity of it and it will append OVM_NONE as severity
so if you call ovm_report_error with irrespective of OVM_(NONE|MED|LOW|HIGH|DEBUG) it is going to be printed.
I am expecting the same functionality in UVM also.
But, this seem to be an area to fix, as UVM_ERROR messages, no one would want to filter in the logs. Not sure if UVM later versions have a fix for this.
The suggested coding pracise, as I understand would be:
Always pass verbosity value of UMV_NONE/OVM_NONE to ovm_report_error.
OR
Use macro uvm_error/ovm_error instead, that defaults the verbosity as UVM_NONE.
From ovm 2.0.3 version onwards they have fixed this issue.If you look at the ovm 2.0.3 release notes.
All OVM library ovm_report_warning,ovm_report_error and ovm_report_fatal messages were changed to have OVM_NONE
verbosity to prevent user-configured verbosity settings from inadvertently suppressing them.
The mantis you have pointed tells the signature difference between `uvm_error and uvm_report_error and also the problem mentioned by San in UVM methodology.
you mean't say that this problem is still persist in ovm-2.1.2(the last release), I don't think so.
i have checked with two releases i.e ovm-2.1.2 and ovm-2.0.2
ovm-2.0.2 has suppressed the ovm_repor_error if message verbosity greater than configured verbosity,but ovm-2.1.2 did not.
If you look at ovm_report_server::report function in src/base/ovm_extern_report_server.svh
In ovm-2.1.2 src/base/ovm_extern_report_server.svh //
if(severity == ovm_severity'(OVM_INFO) && verbosity_level > rh.m_max_verbosity_level)
return;
In ovm-2.0.2 src/base/ovm_extern_report_server.svh
// filter based on verbosity level
if(verbosity_level > rh.m_max_verbosity_level)
return;
If you look at the code of ovm-2.1.2, the function will return empty without printing the message, only if it is ovm_report_info and the message verbosity level is greater than the configured verbosity. Whereas for ovm_report_(warning|error|fatal), the messages will be printed irrespective of the message verbosity level.
If you look at the code of ovm-2.0.2, the function will return empty without printing the message for all ovm_report_(info|warning|error|fatal) if message verbosity level is greater than the configured verbosity.
